Activity › Forums › Compression Techniques › Compiling ffmpeg just to capture single frames
  • Compiling ffmpeg just to capture single frames
    Posted by Rodrigo Br on August 16, 2012 at 2:04 am
    For a personal personal project I’m thinking in use ffmpeg to capture, in fixed intervals, single frames from a webcam. As the computer has very few resorces, I was wondering if you guys could help me to compile ffmpef with just enough to do the job.
    Any help will be apreciated.
    Tomás Hernández replied 14 years, 1 month ago 3 Members · 2 Replies
  • Reuben Martin
    August 17, 2012 at 9:56 pm
    https://ffmpeg.org/trac/ffmpeg/wiki/CompilationGuide
    using the help option with the configure script will give you a listing of all the features and options that can be enabled or disabled
  • Tomás Hernández
    August 26, 2012 at 1:07 am
    Perhaps I am wrong, but if you are on Windows, download de last ffmpeg version from zeranoe, and try this on the command line:
    ffmpeg.exe -i “INPUT_FILE -y -f image2 -ss 20 -sameq -t 0.001 -s 126*95 “OUTPUT_NAME.jpg”
