Activity Forums Panasonic Cameras Compatibility question: Panasonic AJ-PCD10 + MacBook Pro + Dual G5 tower
  • Compatibility question: Panasonic AJ-PCD10 + MacBook Pro + Dual G5 tower
    Posted by Doug Haight on October 8, 2009 at 3:26 pm
    Camera: Panasonic HPX170
    Computer: MacBook Pro, 10.5.8 in field, Dual G5 1.67 for FCP editor
    Current P2 transfer method: Duel adapter to MBP via ShotPut for verification and transfer to two separate external drives
    Duel adapter is workable but finicky and doesn’t work with G5 editor.
    I am looking to buy a Panasonic AJ-PCD10 for use with both MBP and G5. I am getting lots of varying reports about success with either/both. Assuming I have all the correct drivers in place and stay away from OS X 10.6, has ANYONE had success with the AJ-PCD20 and MBP & G5? Can you give me any tips on making this work consistently?
    Amazing how I can’t get a straight answer to this, on the Panasonic site, here or elsewhere. Any help?
    Doug H
    Samuel Small replied 14 years, 3 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    October 8, 2009 at 7:43 pm
    PCD10 or 20? You mention both.
    PCD20 Should work.
    Jeremy
  • Doug Haight
    October 8, 2009 at 11:20 pm
    Oops. Yes I am looking to buy the Panasonic AJ-PCD10. Will that work with my hardware?
    Doug H
  • Jeremy Garchow
    October 9, 2009 at 6:28 pm
    I believe the PCD10 is windows only.
  • Samuel Small
    June 16, 2012 at 6:04 pm
    Yes Panasonic AJ-PCD10 is windows only.
    Has anyone tried mounting it to a mac that is running windows OS via bootcamp?
