Activity Forums Apple Motion Compatibility between Motion Versions 2,3,4 and 5
  • Compatibility between Motion Versions 2,3,4 and 5
    Posted by Hans Huber on February 5, 2012 at 1:55 pm
    Hello Creative-COW-Community,
    in a project, i am using Motion-Files (*.motn), which were created with Motion 2 and 3. On a new Machine i have newer Versions (4 and 5) and when i try to import the old *.motn-files the whole system freezes and finally the Application crashes. On the new machine is FinalCutPro7 installed, which shows the same behaviour.
    My questions are:
    Has anyone made similar experiences?
    Could embedded media with wrong absolute path-referencing be the problem?
    Is it in general possible to import old *.motn (from Version 2 and 3) files into Motion4?
    In Motion5 the import does not allow *.motn, which are greyed out. Is there any way to import the old *.motn’s into Motion5 or has the architecture changed so drastically, that i can throw the old projects away?
    Thank you in advance,
    Hans
    Hans Huber replied 14 years, 7 months ago 2 Members · 3 Replies
  • Mark Spencer
    February 5, 2012 at 3:12 pm
    Rather than “importing” the files, try *opening* them. You should be able to open older projects in new ever versions, including Motion 5.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Hans Huber
    February 5, 2012 at 3:46 pm
    Hi Mark,
    thank you for your fast answer. Opening the old *.motn files in Motion5 is possible. I have tried that as well and the result is the spinning beachball and a complete systemfreeze. The process is taking over 100% of my CPU, the fans go loud and i can’t do anything but an hard reboot. Have you any idea, why this is happening?
    Kind regards,
    Hans
  • Hans Huber
    February 6, 2012 at 2:31 pm
    If anyone has the same Problem, there is a Dialog, when opening the file, where you can choose to open the Original or make a new project called “ohne Titel” in the german version. Never ever click the second option. Opening the original works fine, i am so sorry for not having tested this enough before posting!
