Activity Forums Apple Final Cut Pro Legacy compatibility between AVID and FCP
  • compatibility between AVID and FCP
    Posted by Peter Frick on July 19, 2006 at 10:50 am
    HI
    I’m working with files created on an AVID-station. Trying to import this and use it within fcp does not work. The files are uncompressed 8-bit 16:9. It says Avid meridian on the filetype but it’s useless in Fcp.
    Any ideas?
    Peter
    Bob Flood replied 20 years, 2 months ago 7 Members · 12 Replies
  • 12 Replies
  • Walter Biscardi
    July 19, 2006 at 11:00 am
    That’s an Avid codec so you need to have that codec installed on your machine to make it work, though I’m not sure you’ll be able to play anything in realtime with that codec. I believe you need the Avid hardware to make that work.
    The Automatic Duck Pro Importer allows you to bring in an Avid Project, media and all, and work with it in FCP.
    Walter Biscardi, Jr.
  • Peter Frick
    July 19, 2006 at 11:24 am
    OK thanks a lot.
    Peter
  • Craig Loco
    July 19, 2006 at 11:40 am
    Howdy, Try downloading the FREE AVID DV progam, this installs a majority of the CODECS from AVID ….
    Cheers
  • Peter Frick
    July 19, 2006 at 12:03 pm
    These free dv avid does that include working with uncompressed media like I do?
    Peter
  • Roddy Jamieson
    July 19, 2006 at 1:14 pm
    Avid codecs WON”T work with FCP. Download the codecs and export from QuickTime with the Apple uncompressed codec. Then import into FCP. You’ll need a lot of disc space!
    Roddy Jamieson
  • Tom Matthies
    July 19, 2006 at 1:17 pm
    Do a Google search for the codec. I don’t remember exactly where I found it a while ago, but it is out there. I have it in my system and it works fine although, as Walter notes, the files will not play back well without rendering lacking the Avid hardware.
    Tom
  • Donato M. rondinelli
    July 19, 2006 at 2:58 pm
    Avid Quicktimes will work on in FCP, Avid omfs will not. If you exported a QT your OK, but you can’t just grab the files from the OMFI folder.
    Install the Avid codec & all QT will play. https://www.avid.com/onlineSupport/browse.asp?productID=0&topicID=404&browse=
    -dMR
    July 19, 2006 at 3:06 pm
    The above statement applies to you situation, uncompressed. I thought in DV land the Adrenaline captured in QTs? Not sure though, never worked in DV rez. My Adrenaline is in pieces right now and can’t check that out…I’m too busy cutting in FCP!
    -dMR
  • Bob Flood
    July 19, 2006 at 3:20 pm
    The
    can i call you The? or is it thefreak? how about mr freak? 🙂
    this may be obvious, but do you have a kona or a blackmagic? if so install the software codecs on the avid, and export in the native file format for fcp
    OR do as mentioned above, but make sure you are exporting out of quicktime in a kona or bm native codec, not just apple uncompressed (for more infor go the aja website and look under kona downloads)
    hope this helps
    bee eph
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • Peter Frick
    July 19, 2006 at 4:08 pm
    Hi Bob. My name is really Frick but I unfortunately was in a bit of a hurry when I came up with that stupid name thefreak. Anyway. My graphicsguys have exported the stuff I need from After effects and using an AVID-codec which does not work. What we evntually did was to export the material, a 30 sek bumper, as a tif sequence then ran that through quicktime exporting it as 8-bit uncompressed. I use black magic. The strange thing is that when I tried to import the sequence straight into fcp I got an error message, insufficient content for edit. I think this is a bug.
    See you
    Peter
