Activity › Forums › Apple Final Cut Pro Legacy › Compatibility
  • Posted by Jack Fox on June 21, 2012 at 2:23 pm
    It has been awhile. In the past I used 24p Advanced for all my video needs, but this time I need to be compatible. The problem is I cannot find a “Scene File” on my DVX100 that is appropriate. I suspect 30fps is what I need. Please advise what and how to choose a “Scene File” that is compatible with other cameras (30fps non-DVX100 SP variety) and is good for interior lighting.
    Or can I just shoot in 24p Advanced and just capture in 30fps?
    Thank you.
    jmf
    Jack Fox replied 14 years, 3 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    June 22, 2012 at 2:25 pm
    The 30fps is really 29.97… or if you shot 24p (NOT advanced) it too will be 29.97 with a pulldown. The advanced 24p doesn’t look all that great if you need to deliver 29.97.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Jack Fox
    June 26, 2012 at 10:30 pm
    I guess I can shoot in 24p (not advanced) to get it in the timeline as a 60i interlaced footage that would make it more compatible with other camera rolls? The question is what capture settings to use in FCP?
    jmf
  • Jack Fox
    June 28, 2012 at 9:46 pm
    Thanks. I’ll use Scene File F5. Should the “Rec Speed” be set to “SP” or “LP”?
    jmf
