Activity Forums Adobe After Effects Expressions Compare two values
  • Compare two values
    Posted by Tristan Nieto on February 25, 2009 at 11:37 am
    Is there an expression that can operate like a comparison node, as in compare 2 values and pick one.
    For example – compare 2 layers’ x-position values, pick the larger one and set that layer’s opacity to 0%.
    Or something to that effect?
    Cheers
    Tristan Nieto replied 17 years, 6 months ago 2 Members · 3 Replies
  • Filip Vandueren
    February 25, 2009 at 1:41 pm
    Both layers would need an expression applied to opacity:
    1st layer:
    l1=thisLayer;
    l2=thisComp.layer("second layer");
    if (l1.position[0]>l2.position[0]) {
    100;
    } else {
    0;
    The 2nd layer could just have an expression for opacity like:
    l2=thisComp.layer("first layer");
    100 - l2.opacity;
    or you can re-use the first expression and change the first two lines to:
    l1=thisComp.layer("first layer");
    l2=thisLayer;
    100;
    } else {
    0;
  • Filip Vandueren
    February 26, 2009 at 1:32 am
    Obviously, in that last expression 100 and 0 need to be reversed
    l2=thisLayer;
    0;
    } else {
    100;
  • Tristan Nieto
    February 26, 2009 at 12:07 pm
    Works like a charm.
    Nice work Filip, thanks for helping out.
    Tristan
