Activity Forums Adobe After Effects Expressions Compare sourceText
  • Compare sourceText
    Posted by Avinash Ramanath on October 15, 2019 at 12:36 pm
    Is there a way to compare source text of the current layer with the text layer of another comp. I need to use this information to control some keyframe values
    currently am using the below method but not getting any results.
    var chkText = comp("Comp 1").layer("Line_1")("ADBE Text Properties")("ADBE Text Document");
    if(text.sourceText === chkText){
    text.sourceText = "True"
    else{
    text.sourceText = "False"
    Avinash Ramanath replied 6 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 15, 2019 at 4:38 pm
    I think you just need to add .value when you reference the text. I’d do it like this:
    var chkText = comp(“Comp 1”).layer(“Line_1”)(“ADBE Text Properties”)(“ADBE Text Document”).value;
    text.sourceText.value === chkText ? “True” : “False”;
    Dan
  • Avinash Ramanath
    November 4, 2019 at 6:36 am
    Sorry for the late reply, Thanks for this Dan, I will check and share an update.
