Activity › Forums › Blackmagic Design › compare Decklink uncompress edit mode with premiere cs3 uncompress mode
  • compare Decklink uncompress edit mode with premiere cs3 uncompress mode
    Posted by Sun Da qing on August 21, 2007 at 4:03 am
    I had compared Decklink uncompress edit mode with premiere cs3 uncompress mode. I use same 8bit uncompress clip and same timeline.but the Decklink mode is slower,and ram used is 1.5G but cs3 only 0.9G used,and very fluent play. The timeline is four layers picture in picture.
    vista 6.4 decklink drivers pr cs3 2Gram Q6600 cpu raid
    Sun Da qing replied 19 years, 1 month ago 1 Member · 1 Reply
  • Sun Da qing
    August 22, 2007 at 3:18 am
    Can I output video use decklink in premiere edit mode? like matrox Parhelia video output.
    Can I switch decklink and premiere mode? I rembered the old premiere can do.
