Activity Forums Adobe After Effects Expressions Compare Arrays in Extendscript
  • Compare Arrays in Extendscript
    Posted by Rodrigo Aben on October 12, 2022 at 4:49 am
    How do I check if an array contains values of another array?
    Lets say I have:
    myLayers: [1,12];
    containingLayers: [1,2,3,4,5];
    How do I check is the second array contains both values of the first one?
    Rodrigo Aben replied 3 years, 10 months ago 3 Members · 5 Replies
  • Dan Ebberts
    October 12, 2022 at 5:26 am
    If you’re using the JavaScript engine, something like this should work:
    myLayers = [1,12];
    containingLayers = [1,2,3,4,5];
    success = true;
    for (var i = 0; i < myLayers.length; i++){
    if (! containingLayers.includes(myLayers[i])){
    success = false;
    break;
    success
  • Rodrigo Aben
    October 15, 2022 at 3:51 am
    Function .includes does not exist on extendscript
  • Dan Ebberts
    October 15, 2022 at 6:34 am
    I’m guessing you either have File > Project Settings > Expressions > Expression Engine set to Legacy Extendscript (instead of JavaScript) or you’re running an old version of AE
  • Filip Vandueren
    October 15, 2022 at 7:05 am
    If you need it in scripting, it’s easier to implement with indexOf(). This is also not in Extendscript, but it is a bit easier to ‘polyfill’:
    if (!Array.prototype.indexOf) {
    Array.prototype.indexOf = function(obj, start) {
    for (var i = (start || 0), j = this.length; i < j; i++) {
    if (this[i] === obj) { return i; }
    return -1;
    myLayers = [1,12];
    success = true;
    if (containingLayers.indexOf(myLayers[i])==-1) {
    success = false;
    break;
    succes;
    (Haven’t tested this)
  • Rodrigo Aben
    October 16, 2022 at 1:21 am
    That solved beautifully, Filip. Thanks a lot!
