Activity Forums Adobe After Effects Comp won’t render out Rotobrush shots
  • Comp won’t render out Rotobrush shots
    Posted by Clay Coleman on January 30, 2013 at 1:33 pm
    Working on a 2012 iMac, AE CS6.
    I have a 12 sec. composition with 5 layers of ProResHQ video. On two of the video tracks, I’ve used Rotobrush.
    When I hit add to render queue and play out, AE does not render out the Rotobrush layers. Very frustrating. What am I missing?
    Clay Coleman replied 13 years, 7 months ago 2 Members · 4 Replies
  • John Cuevas
    January 30, 2013 at 2:04 pm
    When you finished using the rotobrush, did you press the “freeze” button in the layer window?
    AfterEffects CS5: RotoBrush
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Clay Coleman
    January 30, 2013 at 2:36 pm
    No, did not press the freeze button.
  • John Cuevas
    January 30, 2013 at 2:56 pm
    Rotobrush really saves time, but it definitely has a learning curve. That link above is a pretty comprehensive tutorial on how to use it and it’s feature. If you have the 25 minutes, it’s well worth checking out.
    Thinkck.com
  • Clay Coleman
    January 30, 2013 at 5:21 pm
    Ah, yes. Brilliant. The tute I watched was nowhere near that good. Thanks muchly for the link. Making sense now and up and running.
    Cheers,
    Clay
