  • Posted by Eli Mavros on September 21, 2006 at 2:18 pm
    Say I have a bunch of tapes and I capture spots off of each of them, lay them down in a timeline and make a master comp tape. Now if I made an edl and gave it to someone so that they could capture the spots it would ask them to pop in the original tapes. How would I make an EDL that would reflect the reel name and timecodes off the new comp tape? I want to make a comp tape and give it to another editor with an edl which would allow him to capture the spots off the one tape. I know this can be done…I’m just having a brain fart.
    Thanks for you help,
    Eli
    Eli Mavros
    Neil Ryan replied 20 years ago 5 Members · 11 Replies
  • 11 Replies
  • Jerry Hofmann
    September 21, 2006 at 3:57 pm
    recapture the comp tape capturing each spot separately… put them back in a sequence, and export the EDL of that sequence.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Eli Mavros
    September 21, 2006 at 4:07 pm
    Thanks for the quick response. Bummer…this is the easiest way?
    Best,
    Eli
    Eli Mavros
  • Eli Mavros
    Thanks for the quick response. Bummer…this is the easiest way? It is a very long tape.
    Best,
    Eli
    Eli Mavros
  • Dean Sensui
    September 21, 2006 at 8:06 pm
    Just wondering: Why would you want to do that?
    Dean Sensui — http://www.HawaiiGoesFishing.com
  • Eli Mavros
    September 21, 2006 at 8:17 pm
    I am leaving my current job, so they are having the new company montage cut out of house and we have tons of master tapes, so we just want to send up one long digibeta to the editor who is going to cut it. I work on FCP and he works on Avid and he requested a digibeta.
    Best,
    Eli
  • Jerry Hofmann
    September 21, 2006 at 8:19 pm
    Yeah, other than just logging it for him? ie. no real EDL but at least a starting log… You could get the log from the sequence if it matches the timecode of the recording…?
    Jerry
  • Dean Sensui
    September 21, 2006 at 8:25 pm
    Another way is to find out what file format the Avid editor can use, then export the individual clips from the FCP project.
    Send the clips on a bunch of DVD’s or on a portable Firewire drive.
    The editor can then simply drag/drop the exported clips.
  • Michael Gissing
    September 22, 2006 at 12:59 am
    Old fashioned EDL management software like Shotlister would enable you to log the new digi beta tape, creating an EDL of the new tape.
  • Neil Ryan
    September 22, 2006 at 2:57 am
    [Michael G] “Old fashioned EDL management software like Shotlister would enable you to log the new digi beta tape, creating an EDL of the new tape.”
    We’ve come a long way since then … some of it in reverse …
  • Michael Gissing
    September 22, 2006 at 8:25 am
    I still have Shotlister running on PC’s in each studio. Very handy.
