Activity Forums Adobe After Effects Comp size vs Layer size
  • Comp size vs Layer size
    Posted by Abram Siegel on August 5, 2011 at 3:05 am
    I’ve started a new comp sized 1024 x 768 and I’ve imported a png layer the exact same size and for whatever reason they are not the same size! My png is wider than the comp. What is going on? I’ve started over from scratch several times with same result.
    Abram Siegel replied 15 years, 1 month ago 2 Members · 2 Replies
  • Todd Kopriva
    August 5, 2011 at 4:31 am
    I’m guessing that you’re interpreting the pixels in the footage item as being of a different pixel aspect ratio than that of the composition.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Abram Siegel
    August 5, 2011 at 1:36 pm
    Thanks for the response. If I understand correctly, image files are in square pixels, so I told AE to use square pixels in the comp and it seems to have worked. Thanks for helping a noob!
