Activity › Forums › Adobe After Effects › Comp Settings & Lossless
  • Comp Settings & Lossless
    Posted by Robby Monk on May 20, 2014 at 7:33 pm
    I am a beginner in the video world. I just learned how to spell DSLR – that is how young I am in this industry.
    The footage I am shooting seems a bit soft (not sharp), and I am not sure if I have my comp settings set correctly and/or rendering out my footage properly.
    I shoot with a Canon 7d. I shoot at 1920×1080 (24fps) and have my comp settings at HDTV 1080 25. When I render, I am using Quicktime with MPEG – 4video.
    Is this correct or am I a complete idiot with the wrong settings?
    Daniel Waldron replied 12 years, 4 months ago 3 Members · 5 Replies
  • Walter Soyka
    May 21, 2014 at 12:54 pm
    [Robby Monk] “The footage I am shooting seems a bit soft (not sharp), and I am not sure if I have my comp settings set correctly and/or rendering out my footage properly.”
    Are you sure the footage itself is sharp? Depending on your lens choices, your depth of field may be very shallow, which makes maintaining tack-sharp focus very challenging.
    [Robby Monk] “I shoot at 1920×1080 (24fps) and have my comp settings at HDTV 1080 25. When I render, I am using Quicktime with MPEG – 4video.”
    Why the frame rate difference between your footage and your comp?
    Also, I’d suggest dumping QuickTime/MPEG-4. For general use, I’d suggest you instead render with the lossless preset, then use Adobe Media Encoder to make an H.264 MP4.
    Walter Soyka
  • Robby Monk
    May 21, 2014 at 1:04 pm
    Thanks Walter. No clue why I was off with the frame rate and my comp. Chalk that up to my stupidity.
    I will try your suggestion on using the Lossless preset. So once that is rendered, I then drop that finished file into Adobe Media Encoder? I’ll let you know how that turns out!
    Thanks again!
    Robby
  • Walter Soyka
    May 21, 2014 at 1:50 pm
    [Robby Monk] “No clue why I was off with the frame rate and my comp. Chalk that up to my stupidity.”
    Let’s chalk it up to being a beginner!
    Since you’re new to After Effects, I’d recommend the following link, in which Adobe’s Todd Kopriva pulls together some important introductory materials:
    https://blogs.adobe.com/toddkopriva/2010/01/getting-started-with-after-eff.html
    [Robby Monk] “I will try your suggestion on using the Lossless preset. So once that is rendered, I then drop that finished file into Adobe Media Encoder?”
    Yes, using an H.264 preset. I like the Vimeo H.264 presets as a good starting point.
    Walter Soyka
  • Robby Monk
    May 21, 2014 at 5:30 pm
    Excellent. Thank you!
  • Daniel Waldron
    May 22, 2014 at 9:29 pm
    Adobe TV and and Andrew Kramer’s Basic Training are also great free resources to teach yourself the basics of After Effects.
