Activity Forums Adobe After Effects comp settings for sequential image sequence (not for 3d)
  • comp settings for sequential image sequence (not for 3d)
    Posted by Chris Miller on June 21, 2007 at 8:53 am
    Hi
    I have a very large back catalogue of images that I am putting together for a gallery projection. The client has been using iphoto up and till now which looks great but it has its obvious limitations. My question(s) is this:
    What should my comp settings be (It will probably be projected by a hi def projector in the uk) and how should I export it?
    Will I have to play it from hard drive to get the best quality. I tried a slide show in dvd studio pro and it looked seriously compressed.
    Is there a ken Burns style effect/ expression I can use?
    Thanks in anticipation
    Roland R. kahlenberg replied 19 years, 3 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    June 21, 2007 at 1:40 pm
    You seem to have too many Qs. Not a bad thing but it’s all over. I’m not even sure how to sort things out for you.
    But I’ll try. First off, you’ll need to ascertain the playback device for the presentation – computer/DVD/HD DVD/BR DVD etc.
    Once you know that, you’ll have a definitive answer to what your comp settings should be.
    On a seperate but related issue, what are the pixel dimensions of your images? And with regards to the Expression, what are you intending to do with the images, in AE? You’ll need to provide more info on this.
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
