Activity Forums Adobe After Effects Comp Rez Change
  • Comp Rez Change
    Posted by Chip Hess on February 19, 2011 at 12:09 am
    I have some purchased projects I want to downrez a bit.
    1080 into 720. Is there a way to downrez all the included components in a batch, rather then scaling down all individually?
    So basically create a new project/comp with all components matching.
    Chip Hess replied 15 years, 7 months ago 2 Members · 2 Replies
  • Cory Petkovsek
    February 19, 2011 at 3:03 am
    Make a comp at the resolution you want. Put all your purchased comp into the new one and scale to the appropriate resolution.
    Or if you want 10 purchased comps in your project, add them all. Select all, press ‘s’ for scale, change the scale for one with them all selected and they’ll all change.
    What you don’t want to do is go into the purchased comp and scale those layers.
    Cory
    Cory Petkovsek
    Corporate Video
  • Chip Hess
    February 19, 2011 at 11:47 pm
    Thanks very much, guys!
