Activity › Forums › Adobe After Effects › comp preset for HD 720p
  • Steve Roberts
    August 23, 2007 at 3:21 pm
    Does this help? Found it on the web by Googling D5, 720p and “after effects”.
    https://www.screenvision.com/static/pdf/Digital%20Specs.pdf
  • Kevin Camp
    August 23, 2007 at 4:24 pm
    you can easily just change the frame rate to 59.94… d5 at 720 will work with that frame rate.
    what i’m a little unsure about is the pixel aspect ratio… since i don’t know what the par is for d5, i would use a square pixel comp (1280×720, square px)… it’s always easier to scale it down if it is a 1.3 par (960×720, 1.3 px). and, as gets pointed out here often, some effects are not non-square px friendly anyway.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Accountclosedduetonorealnameused
    August 23, 2007 at 7:10 pm
    it does.
    thank you kindly
