Activity Forums Zaxwerks Comp Lights and Shadows
  • Comp Lights and Shadows
    Posted by Simon Roughan on February 19, 2007 at 3:10 pm
    I built a podium in Invigorator, and set it into a 3D room (floor and walls). I want the camera to track in slowly and then a spot turns on and lights up the podium. How do I set it up that the podium casts a shadow onto the floor and walls behind it? Im using comp camera and lights.
    Invig 3.0.9 classic, plus AE 6.5 pro.
    THanks in advance
    Simon
    Simon Roughan replied 19 years, 6 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    February 20, 2007 at 3:35 am
    Hi Simon,
    The simplest way to get the shadows you want is to build the 3D room inside of Invigorator and use Invig’s lights and shadows. You can then use Lux or T-Beam to create the appearance of a volumentric spotlight.
    Alternately, you can enable AE’s shadow casting/receiving on the light, the receiving layers (floor and walls) and turn the layer to which you’ve applied Invigorator into a 3D layer and enable shadow casting. This will work, but your camera move may break the illusion of the Invig object being a 3D object in the rest of the 3D world you’re creating. This will happen if the Invig layer does not maintain its orientation to the camera.
    Jon
  • Simon Roughan
    February 20, 2007 at 9:02 am
    thanks for the reply. I’ll play around with it a bit…
    thanks again
    Simon
