Activity Forums Adobe After Effects Comp from 960 x 540 to 1920 x 1080
  • Comp from 960 x 540 to 1920 x 1080
    Posted by Joey Condeelis on June 11, 2011 at 11:06 am
    I built this 50 layer comp in low res 960 x 540 with about 40 low res .tiff sequences. Now that my comp is finished I have re-render all my .tiff sequences out 1920 x 1080 High Res. Is there some easy way to convert my low res comp in AE to the new high res I now need? What is the easyest way to turn my low res AE comp into the high res? Will all the mask I made on some of the layer step up to the high res? Yes I have just learned in the furture to build my comps the other way around in AE, high res:) Thank you
    THANKS
    Todd Kopriva replied 15 years, 2 months ago 2 Members · 1 Reply
  • Todd Kopriva
    June 11, 2011 at 8:15 pm
    There are some instructions and resources here for scaling an entire composition.
    I’m glad to see that you’ve learned your lesson about working at the higher pixel dimensions to start with.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
