Activity › Forums › Adobe After Effects Expressions › Comp duplicate – Converting comp name in expression
  • Comp duplicate – Converting comp name in expression
    Posted by Igor Stikic on April 16, 2014 at 1:12 pm
    I have comp 03 PROFILE in which I have COMP 2. I have expression on it.
    When I duplicate comp 03 PROFILE and get the 03 PROFILE 2, expression stay the same and I want to part (“03 PROFILE”) changes in (“03 PROFILE 2”) Is that possible?
    Thanx
    time+comp("03 PROFILE").layer("MANIPULATION").effect("time")("Slider")
    Dan Ebberts replied 12 years, 5 months ago 2 Members · 3 Replies
  • Dan Ebberts
    April 16, 2014 at 5:44 pm
    Is Comp 2 a layer in 03 PROFILE, and the expression is on that layer? If so, you could just change your expression to this:
    time+thisComp.layer(“MANIPULATION”).effect(“time”)(“Slider”)
    If the expression is inside Comp 2 though, then I don’t know what to suggest.
    Dan
  • Igor Stikic
    April 16, 2014 at 9:22 pm
    Sorry expression is in Comp 2.
    Igor Stikic
  • Dan Ebberts
    April 16, 2014 at 9:36 pm
    I suspect you want to have the expression behave differently, depending on which comp the expression’s parent comp (Comp 2) is nested within. That won’t work. You would have to duplicate Comp 2 as well and point the expression in the new sub comp to the new master comp. This could be done with a script, but it might be more trouble than it’s worth.
    Dan
