Activity Forums Adobe After Effects comp disappear wtih four square points appear…
  • comp disappear wtih four square points appear…
    Posted by Heather Crank on August 31, 2012 at 11:21 pm
    Hello Everyone,
    I’ve encountered this a couple of times…and can’t figure out what causes this. Every once in awhile, I open an ae file and the main comp is blank with four square points. If I drag out the points to each of the four corners in the comp, bam, the comp image appears. Has anyone experienced this? Does anyone know what it happens?
    H
    Heather Crank replied 13 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
