Activity Forums Boris FX Commotion and BCC
  • Commotion and BCC
    Posted by Sergio Anaya on February 2, 2007 at 7:26 pm
    I saw the AVID LE7 page, there is mention about the commotion effects and one of the effects I liked is the threshold effects, Is this possoble to do it with Boris Red 3? I saw in the BBC effect list the effects composite chroker I am interesting how to use it? what is one of its applications? I mean normally how to use it oro what it is for?.
    That I am trying to say I want to have my video as cow (BW), Is this possible with Red3 or with LE6.1?
    Regards
    Peter Mcauley replied 19 years, 6 months ago 2 Members · 2 Replies
  • Peter Mcauley
    February 5, 2007 at 4:52 pm
    Very easy to do with RED, but it requires two filters. Simply add the hue-sat-lightness filter to the clip that you want to change and set the saturation parameter to negative 100 (-100). Then add the brightness-contrast filter to the clip and set the contrast value to positive 100 (100). Then you can use the lightness parameter in the hue-sat-lightness filter to control the values that you want to threshold.
    I hope this helps.
    Peter.
  • Peter Mcauley
    February 6, 2007 at 7:49 pm
    You can also use the BCC Pixelchooser as a levels effect – simply apply the Pixelchooser to the clip and select threshold from the matte type pop-up in the matte section.
    Cheers,
    Peter.
