Activity › Forums › Adobe After Effects › COMMON AFTER EFFECTS QUESTIONS !!!!!!!!!!! PLEASE LOOK HERE FIRST
Posted by Joel Hooton on October 10, 2006 at 10:20 pmSystem/Software Version Issues
How do you open an AE 7.0 file in AE 6.5?
Cash Case replied 15 years, 11 months ago 20 Members · 23 Replies -
Spiritegun
January 17, 2007 at 9:23 amWhen putting in a gradation effect in the object, it used the Ramp and it put in an effect. (1)
It used the Ramp and when puts in an effect the object moves, the change of color occurred. (2)
The object moves and the plug-in which is not change of color or it is what with the method which is simple?
(3)
thank
Coen Huisman
April 7, 2008 at 3:45 pmHey Guys!!
Is there someone who can help me out?! with a 3D after effects problem?
I’m working in CS3 for Mac and everything is just working fine, that’s hopefully not athe problem. I just can’t fix this 3D composition layer problem: I build like cubes in 3D and import this cube into a new compostion to build up complete buildings and stuff, but the 3D composition layers won’t grap into eachother, There in front of eachother! witch is impossible in 3d! If i change the order of the layer i can change this but if i go round with my camera the same thing happens the other way around.
Is there someone who can help me out, I’m starting to lose my patience!!
already thanksCoen
Laurence Mcnamara
May 13, 2008 at 11:40 pmHi. I have several layers linked together that animate a figure moving from right to left across the screen. I thought that if i copied and pasted those layers, and then flipped them, it would also flip the motion direction, but it did not. It simply appears as though the copied figure is moving backwards along the same position path as the original figure / layers.
can the movement path be flipped, or do i need to re-do the position path for the copied layers in order to get them going in the opposite direction?
Laurence -
Jean Mathis
July 7, 2008 at 10:44 amI want to transform vector shapes from illustrator into shape layers in AE any one knows how to do that ?
I know of course how to transform vactor shapes from illustrator into masks or motion paths in after effects so don’t get me wrong this is different.
Thank you in advance.
Jean -
Andy Finlay
October 2, 2008 at 7:56 pmYe that is a fair question. Which im having difficulty with aswell..
Does anyone know how to do edit Ai paths and animate them as shape layers in AE..??
Pleeeease!
Rob Jackson
February 28, 2009 at 7:47 pmI see this question posted under “Common After Effects Questions,” but I don’t see an answer anywhere. I’m having this exact issue. I know I can hand-do the keying for the second object, but I’d like it to be an exact reflection.
My project is taking two objects, having them on opposite sides of the screen, move apart, collide, bounce back, collide again, etc. Think of rams butting heads or football helmet graphics colliding.
Rob Jackson
Rob Jackson
February 28, 2009 at 9:16 pmOK. Answered it myself by accident. Posted a video which hopefully explains better than my words.
Answer: Duplicate the original comp. Add the second comp to the original comp. Select one of the comps, using the bounding box drag one side to the other. This will flip that comp over.
Kim Ranzani
May 20, 2009 at 12:38 pmif what you want is reversing the motion path you can select the keyframes of the motion path on the layers you want to flip and rigth click–>keyframes assistant–>Time reverse keyframes
hope it helps!! bye!
Adedeji Henry
July 7, 2009 at 11:16 ampls i will like to learn how to use after eefect from the basics pls can i get help??????????????
karlmani
Dennis Bielawa
September 23, 2009 at 9:25 pmhow do I save video before importing to after effects cs3. any video is not accepted due to wrong extention. thanks
