Activity › Forums › Adobe After Effects › commit a layer to disk
  • commit a layer to disk
    Posted by Jim Dodson on May 26, 2007 at 10:56 pm
    I with know Nucleo Pro you can do this, but is it possible in AE 7. (or CES3) once you have a layer completed that you can commit that layer to disk so it doesn’t have to render with the other layers that you’re still tweaking every time you preview???
    Jim Dodson
    Quad 2.5 gig Mac – OSX
    Jim Dodson replied 19 years, 4 months ago 2 Members · 2 Replies
  • Filip Vandueren
    May 27, 2007 at 12:16 am
    Here’s a recipe:
    Duplicate the layer, and disable the copy (click the eyeball):
    this original will remain there for future reference, if you do decide to tweak the layer some more within this context.
    On the duplicate, visible one: do a precompose, ‘move all attributes…’
    caveat: if you’re using expressions that reference other layer’s properties on this layer: you should change your expressions so they keep working in the precomp
    Now, while having the precomp selected, do Composition-> Prerender.
    In the Render Queue, hit render.
    After Effects will render the precomp and replace all occurances of the precomp with the movie (or pict sequence)
    You can also twirl open “output module” in the render queue before you render and change the setting “Import & replace usage” to “Set Proxy”. Check the manual for the difference between those two options.
    Most importantly, if you use proxies, be sure that your Render Settings are set to use those proxies if that’s the idea…
  • Jim Dodson
    May 28, 2007 at 9:49 pm
    Thanks Flip — that was a great help!!
    Jim Dodson
