Activity › Forums › Apple Final Cut Pro › comminting an edit…
  • comminting an edit…
    Posted by Osmani Tellez on October 31, 2013 at 4:04 pm
    Hi.
    in FCPX..i edited a multicam clip….is there a way to commit to the edit so i won’t be a multi cam clip reference anymore? you know what i mean? i want to commit to clip and make it a regular clip..no a multi cam anymore …
    thanks?
    FCPX 10.7, Motion 5. Canon 5D mark II, T2i, T3i.
    Darren Roark replied 12 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Bill Davis
    October 31, 2013 at 6:51 pm
    Well, you can certainly just Share it as a file – then bring that into a fresh storyline.
    Does pretty much the same thing – plus if you keep the original – you have the ability to re-edit easily.
    FWIW.
    Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
  • Darren Roark
    October 31, 2013 at 7:44 pm
    Why would you need to do that? (I was just asked this by someone and I didn’t have a good answer.)
    It does bug me that you can’t do that.
  • Jacob Brown
    October 31, 2013 at 7:54 pm
    you can also round trip it through davinci resolve and end up with a simple timeline when you reimport the fcpxml
    actually, i wonder — can you export your XML from FCPX, and then just reimport it. Would that then flatten the multicam?
  • Darren Roark
    October 31, 2013 at 9:39 pm
    [Jacob Brown] “i wonder — can you export your XML from FCPX, and then just reimport it. Would that then flatten the multicam?”
    I just did a test in Resolve 10 beta 3, and it does work, just not with multicam clips with pluraleyes synctemp files as I can’t get Resolve 10 to see them. I need to play around with it further.
    The good news is that it does strip the multicam out if all your sound is working and it does come back just fine.
  • Jacob Brown
    October 31, 2013 at 9:43 pm
    yeah i havent used that trick in 10. only resolve 9. i also wasnt using plural eyes
  • Osmani Tellez
    November 1, 2013 at 12:43 am
    that’s good to know..
    doesn’t this option creates some new files and a new event? i really don’t like when back from Resolve that clips duplicate and new events is created…
    is better than nothing..thou.
    thanks a lot for this..
    is there a list of what does go thru to Resolve 10? i think spacial conform doesn’t…will be nice to have a list of everything that works and that doesn’t.
    just checking…
    i will have to do many tests to find out…
    thanks.
  • Darren Roark
    November 3, 2013 at 12:37 am
    Yes it does, but if you change your preferences in FCP X, uncheck “add media to event folder” or whatever it’s called, then merge the events. You will have your new timelines and it will eliminate all the doubling up. (Make sure you back up your event currentversion.fcpevent files first)
    Then change the preferences back to whatever you want. I have a feeling this isn’t going to be the case for long when the new version comes out judging from how iMovie does everything.
