Activity › Forums › DVD Authoring › Commands edition to make the chapter skip button take you to the main menu
  • Commands edition to make the chapter skip button take you to the main menu
    Posted by Rocio Aranda on February 26, 2013 at 5:44 pm
    Hello there,
    is there any way to make the chapter skip button (on your remote control) take you to the main menu in DVDLab Pro?
    Any command?
    Would you mind to show me?
    I don’t understand how DVDLab Pro works with commands?
    thanks
    Rocio
    Christopher Smith replied 13 years, 4 months ago 2 Members · 2 Replies
  • Christopher Smith
    May 22, 2013 at 5:09 am
    I’m not familiar with DVDLab Pro, but I believe the principle would be the same as in DVD Studio Pro.
    Simply set the Next Jump value to Main Menu. (In DVDSP, this Next Jump value is not visible in Basic Connections; you have to switch to see All Connections.)
    When the user hits the Next button, the player will still give them the next chapter, until they run out of chapters on that track. The next press of the Next button (once they’re already in the final chapter of the track) will execute “Next Jump”. So you set that to jump to the Main Menu.
    Christopher Smith
    CBN International
  • Christopher Smith
    May 22, 2013 at 5:12 am
    Rocio,
    I read your earlier post and now I realize what I told you is not the solution to your problem. My solution is for a much simpler issue.
    Christopher Smith
    CBN International
