Activity Forums Apple Final Cut Pro Legacy command+R not rendering
  • Rob Grauert
    December 21, 2009 at 2:06 pm
    Well, for the rendering, when you go to Sequence > Render (or Render All), make sure all those colored bars have check marks next to them. Whatever is check marked is what FCP renders when you press Command + R or Option + R.
    For your screen issue, have you gone to View > Video Playback and make sure the proper selection is checked?
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
