Activity › Forums › Apple Final Cut Pro Legacy › Command Z doesn’t work
Posted by Richard Jordan on April 14, 2009 at 10:22 amI’ve just started using Final Cut 6 on a MacBook Pro and found that the undo keyboard shortcut doesn’t work (command Z). The only way I can “undo” at the moment is from the pull down menu. All other keyboard shortcuts seem to work (as far as I know).
Has anyone experienced anything similar? And what’s the solution?Hendrik Rogez replied 14 years, 5 months ago 3 Members · 8 Replies -
Tom Wolsky
April 14, 2009 at 11:19 amIs this a QWERTY keyboard? Does Cmd-Z work in other applications or the Finder?
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Richard Jordan
April 14, 2009 at 6:17 pmYes it’s a regular QWERTY keyboard (bought in the UK) and cmd Z works fine with other applications.
Tom Wolsky
April 14, 2009 at 7:02 pmTry trashing the FCP preferences.
All the best,
Tom
Richard Jordan
April 14, 2009 at 9:56 pmI went to the FCP preferences but the only options available with reference to the undo is “Levels of undo”. I have 10 (the default). I’ve also found that cmd X, and cmd V don’t work either in my FCP. However cmd C and the redo DO work!
All these keyboard shortcuts are fine for other applications, e.g I’ve just tried them all with excel – no problem
Tom Wolsky
April 14, 2009 at 10:14 pmI didn’t ask you to change the preferences, I asked you to trash your preferences.
https://www.fcpbook.com/Misc1.html
All the best,
Tom
Richard Jordan
April 28, 2009 at 9:42 amTom,
Sorry for my delay in responding; I was away on holiday.
OK, I’ve trashed the FC6 preferences as per:
https://forums.creativecow.net/thread/200/878466It has had NO effect.
Of the basic keyboard shortcuts, the following DO NOT work:
CMD Z, CMD V, CMD X – they only work from the pulldown menu 🙁Working shortcuts: CMD C, CMD shift Z, CMD O, CMD Q, CMD shift N, CMD shift S, CMD S
Richard Jordan
April 28, 2009 at 10:17 amTom,
Cracked it!
Solution: I live in Spain though bought my MacBook Pro in the UK. When I set up the laptop, without thinking I selected the Spanish option for the operating system. This has been the source of the problem. I’ve reverted to the English operating system and all shortcuts work fine now in FC6…. curious.
Hendrik Rogez
April 10, 2012 at 11:24 amHello Tom
I happenend to have the same problem. I’m in Paris and i have a Dutch mac and a French keyboard and i put the language in french. but wat exactly did you doe to fix it up cause i cant find out.
Thanks in advance.
Hendrik
