Activity Forums Adobe After Effects Command M no longer adds to Render Queue
  • Command M no longer adds to Render Queue
    Posted by David Cabestany on May 16, 2012 at 7:03 pm
    I recently upgraded from CS5 to CS5.5 and just discovered that hitting Command M minimizes the window instead of adding the composition to the Render Queue, does anyone know how to remap the keys to that instead?
    Thanks in advance.
    Walter Soyka replied 14 years, 4 months ago 4 Members · 5 Replies
  • Brian Charles
    May 16, 2012 at 7:20 pm
    You must be working on a laptop. Try Command + Control + M.
    Or you can use this script to remap keys:
    https://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail&loc=en_us&extid=1698043
  • David Cabestany
    May 16, 2012 at 7:31 pm
    Nope, I had Use system shortcuts enabled, Todd Kopriva posted the solution in an Adobe forum a few minutes ago.
    Thank you very much for taking the time, though, I really appreciate it.
  • John Cuevas
    May 16, 2012 at 11:40 pm
    Can you post the solution, so if somebody else searches for it they will find it.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • David Cabestany
    May 17, 2012 at 4:33 am
    Sure, just go into AE’s general preferences and deselect Use System Shortcuts.
    Once again thanks to Todd Kopriva for this.
  • Walter Soyka
    May 17, 2012 at 6:15 pm
    [David Cabestany] “I had Use system shortcuts enabled”
    This is a Mac-specific issue. The shortcut you were using, Cmd-M (for Make movie, recently redirected to Add to Render Queue) is the Mac shortcut to minimize a window to the doc. The Replace Footage command is similarly affected, since its default key binding of Cmd-H conflicts with the Mac system shortcut for hiding the application.
    In both cases, if “Use system shortcuts” is enabled, adding the Control key to the AE shortcut (Ctrl-Cmd-M for Make Movie and Ctrl-Cmd-H for Replace Footage) will work.
    For Make Movie specifically, you could also use the traditional shortcut Cmd-Shift-/ to add to the render queue.
    Walter Soyka
