Activity › Forums › Adobe Premiere Pro › Command Line render a Premiere file
Posted by Justin Mettam on July 20, 2015 at 7:17 pmI would like to know if it is possible to command line render a Premiere file.
AfterEffects gives me this capability but I havent found it with Premere.
Thanks in advance.
Justin Mettam
PreViz & 3D-Generalist
mettam@hotmail.com
415 261-7633
https://vimeo.com/album/2527378Justin Mettam replied 11 years, 1 month ago 3 Members · 13 Replies -
Alex Udell
July 20, 2015 at 8:09 pmI don’t think so…
what are you trying to achieve?
Alex Udell
Editing, Motion Graphics, and Visual FX -
Justin Mettam
July 20, 2015 at 8:55 pmAt the moment I set off command line .bat file batch render which renders the frames out of a game engine, and compiles the edit in AfterEffects.
But I want to use Premiere instead of AE to compile the edit. If I knew what the command line render for Premiere was I could add it to my .bat script.
Justin Mettam
mettam@hotmail.com
415 261-7633
https://vimeo.com/album/2527378 -
Alex Udell
July 21, 2015 at 3:57 pmno…
you might be able to do this with an Adobe media encoder watch folder.
when frames are exported out of your engine…
then your .BAT will copy the Ppro project to the watch folder
which would then encode and output however you have it set…
The sequence you want to render must be the ONLY sequence in the root of the PPro project panel.
All others should be in bins (folder) in the project panel.
I just tested it and it worked fine for me….
hth,
Alex Udell
Justin Mettam
July 21, 2015 at 6:09 pmThank you, I will try that out.
Justin Mettam
mettam@hotmail.com
415 261-7633
http://www.JustinMettam.com -
Justin Mettam
July 23, 2015 at 1:00 amI am trying your idea. Though I have come across a problem.
I made a Adobe media encoder watch folder then copied my .prproj into it.
A output folder is automatically made but no movie file has been rendered there.My Premiere project is setup the way you described with only one sequence in the main window and all other elements in bin/folders.
I hope you may help me figure out what I might be missing?
Justin Mettam
mettam@hotmail.com
415 261-7633
Alex Udell
July 23, 2015 at 1:03 pmare you monitoring AME during the test….
you should be able to actually watch the encode happen?
Alex Udell
Alex Udell
July 23, 2015 at 2:42 pmdo you have the “auto encode watch folders” option checked?
Alex Udell
Justin Mettam
July 23, 2015 at 3:17 pmHi. am not at work just yet so I can check at the moment.
But yes I think I did have auto watch checked on.
Would you be able to send me a screen grab of you AME?Justin Mettam
mettam@hotmail.com
415 261-7633
Justin Mettam
July 23, 2015 at 11:53 pmThanks for sending me the screen grab.
So you have a directory that AME watches. When a ###.prproj is place in that watch directory AME should grab it and start rendering it, correct ?
Auto-Encode is checked. I put nothing in the Queue window.
Should I put something in the Queue window?
Or does the watch folder put files in the queue window once it detects a file has been placed in the watch folder?Justin Mettam
mettam@hotmail.com
415 261-7633
