Activity Forums Compression Techniques Command line compressor fails
  • Command line compressor fails
    Posted by Loren Risker on July 13, 2018 at 7:42 pm
    I can’t get compressor to work from the command line, I get an error:
    2018-07-13 12:38:11.801 Compressor[94312:4645537] Error loading /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver: dlopen(/System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver, 265): no suitable image found. Did find:
    /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver: mach-o, but wrong architecture
    /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver: stat() failed with errno=1
    Invalid parameter: /Users/lorenr/Library/Application Support/Compressor/Settings/Apple ProRes 422 test.cmprstng
    Here’s what I’m trying to run:
    /Applications/Compressor.app/Contents/MacOS/Compressor -jobpath ./test.mp4 /Users/xxxxx/Library/Application\ Support/Compressor/Settings/Apple\ ProRes\ 422\ test.cmprstng -locationpath ./testoutput.mp4
    Any ideas? I’m running macOS 10.13.6 and compressor 4.4.1
    OutOfFocus.TV – Music Videos 24/7
    Loren Risker replied 8 years, 1 month ago 1 Member · 1 Reply
  • Loren Risker
    July 13, 2018 at 8:02 pm
    never mind, forgot the -settingpath flag:
    /Applications/Compressor.app/Contents/MacOS/Compressor -jobpath ./test.mp4 -settingpath /Users/xxxxx/Library/Application\ Support/Compressor/Settings/Apple\ ProRes\ 422\ test.cmprstng -locationpath ./testoutput.mp4
