Activity Forums Apple Final Cut Pro Legacy Command line batch
  • Command line batch
    Posted by Darryl Thomson on January 21, 2008 at 5:23 pm
    Is it possible from the command line to run an export from a final cut fcp file eg EXPORT from filename.cfp outputfire.mov with appropriate parameter flags like mov format size etc?
    We regularly have to export several different formats like avi and mov from the same project. It would be easier if we could batch some of this.
    Sorensen doesn’t do avi.
    Dazzer
    Steve Cohen replied 18 years, 8 months ago 3 Members · 2 Replies
  • Arnie Schlissel
    January 21, 2008 at 7:56 pm
    Nope. No command line for FCP at all.
    Take a look in your FCP manual at the batch export function, or take a look at Compressor. both can be used for this kind of thing.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Steve Cohen
    January 21, 2008 at 8:12 pm
    You could also use Cleaner.
    Steve Cohen
    Editor
    O2 Media Inc.
