Activity › Forums › Apple Final Cut Pro Legacy › Command Key Document
Posted by Paul Meyer on January 8, 2009 at 3:42 pmIs there a readily available one sheet document listing Apple FCP command key short cuts? I’m unable to find this document in the manual.
Thanks, Paul
Jeremy Garchow replied 17 years, 6 months ago 3 Members · 5 Replies -
Paul Meyer
January 8, 2009 at 9:47 pmThank you. But, I was looking for something similar to the Adobe command key short cut page that used to be part of their manuals.
Does Apple provide a one page sheet for FCP? -
Jeremy Garchow
January 8, 2009 at 9:52 pmNot that I know of. You might look in to getting a keyboard that has the commands on it or perhaps a control surface from Euphonix.
https://www.logickeyboard.com/
https://euphonix.com/artist/products/mc_control/
Jeremy
Kent Stipp
February 25, 2009 at 3:03 pmJeremy
Curious do you have any experience with the Euphonics control surface with Final Cut? I know as a DAW it is ok but Final Cut? any insight will be helpfulLife Begins at 155mph
Catch it edit it View it
3am Studios llc.
3amstudios.org
Sharedsummitsfever.com -
Jeremy Garchow
February 25, 2009 at 3:23 pmI have one in the shop, but I have been too busy to really get it setup properly and tested.
I have played with it for a few minutes here and there and it is very promising. It really brings a different level of control while editing and I know Euphonix is trying to constantly update the experience for FCP users. What’s nice is the jog wheel, the built in audio faders, and then of course the LCD touch screen which can be used to automate any number of keystrokes or commands. YOu can’t really control filter level parameters as of yet as FCPs interface is a bit limited in that regard, but I know Euphonix is looking to get full compatibility between their surfaces and FCS. If you’re familiar with them in a DAW situation, you should definitely have a look.
Jeremy
