Activity Forums Adobe Photoshop Command “De-Interlace” not currently available
  • Command “De-Interlace” not currently available
    Posted by Phil on December 1, 2005 at 3:09 pm
    Photoshop CS
    I’ve set up an action that first deinterlaces a .png file & then closes it. When i try to batch a folder of .png’s with this action, it gives me the message: Command De-Interlace not currently available. What does this mean?? & how do i fix this??
    thanks!
    Mike Gondek replied 20 years, 9 months ago 2 Members · 1 Reply
  • Mike Gondek
    December 3, 2005 at 6:21 pm
    You image might be in CMYK. Deinterlace does work though on 8 or 16 bit images.
    Is the command available if you try to use it on the image it gets stuck on in the action?
