Activity › Forums › Adobe After Effects Expressions › Comma used in slider WITH text
  • Comma used in slider WITH text
    Posted by Lucy-rae Naylor on December 10, 2019 at 5:03 pm
    Hi so I’ve used this code:
    var num = effect("Slider Control")("Slider")
    num = Comma(num);
    [num]
    function Comma(number)
    number = '' + Math.round(number);
    if (number.length > 3)
    var mod = number.length % 3;
    var output = (mod > 0 ? (number.substring(0,mod)) : '');
    for (i=0 ; i < Math.floor(number.length / 3); i++)
    if ((mod == 0) && (i == 0))
    output += number.substring(mod+ 3 * i, mod + 3 * i + 3);
    else
    output+= ',' + number.substring(mod + 3 * i, mod + 3 * i + 3);
    return (output);
    else return number;
    To put commas in a slider, but what I want is to add “views” to the end of this.
    When I add
    + " views";
    It returns NaN.
    Could someone help me achieve this and explain why the above doesn’t work? Thanks
    Lucy-Rae
    Dan Ebberts
    replied 6 years, 9 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    December 10, 2019 at 5:16 pm
    Try replacing:
    [num]
    with:
    num + ” views”;
    Also, you should move the function to the top of the expression.
    Dan
