Activity › Forums › Adobe After Effects › “Coming back” elements
  • “Coming back” elements
    Posted by Cerutti Nicolas on September 1, 2012 at 3:31 am
    Hi there!
    My question should be simple:
    When I animate the position of an element so it leaves the composition, I would like that this element comes back from the opposite edge. That way, if the element has the size of the composition, I can have a kind of “infinite texture” moving.
    Exemple: my solid leave the composition on the right but as soon as it leaves there, it also comes back on the left (like some old video games).
    I don’t know if I explained clearly. I am almost sure I already used that function but can’t remember which effect or preset it was…
    Thank you in advance!
    Sakat
    Cerutti Nicolas replied 14 years ago 4 Members · 7 Replies
  • 7 Replies
  • John Cuevas
    September 1, 2012 at 4:08 am
    Place the element in your composition and then add the effect Distort -> Offset. Animate the offset position.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Cerutti Nicolas
    September 1, 2012 at 4:26 am
    Oh god.. it was just that.
    Thank you very much!
  • Roland R. kahlenberg
    September 2, 2012 at 10:48 am
    Heya John, Offset works but Stylize>Motion Tile does the same and more PLUS it supports motion blur.
    Cheers
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Cerutti Nicolas
    September 2, 2012 at 4:31 pm
    Yes at first I though about using it. But the problem with motion tile is that it does not make the element “coming back from the opposite side” but adds generated mirrors on its edge. As the layer is bigger, when generating a lot of copy or working with high resolution texture it uses too much memory (correct me if I’m wrong).
  • Walter Soyka
    September 3, 2012 at 2:20 pm
    [Cerutti Nicolas] “Yes at first I though about using it. But the problem with motion tile is that it does not make the element “coming back from the opposite side” but adds generated mirrors on its edge. As the layer is bigger, when generating a lot of copy or working with high resolution texture it uses too much memory (correct me if I’m wrong).”
    If you simply animate Motion Tile’s “Tile Center” property, leaving the tile and output widths and heights at 100, it will work like Offset does.
    Motion Tile only expands the layer if you adjust the output width or height above 100, and it only mirrors the edges if you check “Mirror Edges.”
    Walter Soyka
  • John Cuevas
    September 4, 2012 at 1:05 pm
    Before you animate the motion tile property you need to place it in a precomp of the size size as your final composition. Then you can use it like offset and motion blur.
    Thinkck.com
  • Cerutti Nicolas
    September 14, 2012 at 10:56 am
    Okay, great! Thank you again!
