Activity › Forums › Boris FX › Comet generator
  • Comet generator
    Posted by Steve Pankow on November 18, 2009 at 8:37 pm
    I believe I understand the rational behind the separate Completion/Start time parameters and increased control, but are there some default values to get the comet to begin and end within the duration of the track on the timeline?
    Constantly adjusting stuff to do what on the surface should be nothing more than a simple DVE move seems crazy. Too bad there isn’t a path track available like the text tool has.
    Steve Pankow replied 16 years, 10 months ago 2 Members · 2 Replies
  • Peter Mcauley
    November 19, 2009 at 2:08 pm
    Hi Steve,
    Try this:
    Start with a new instance of the Comet filter applied at default settings to a solid color layer
    Set the Destination Z value to -100
    Set the Completion time to 50
    Set Source XY just on outside of the visible layer area in the comp
    Set the Destination XY to the center of the comp
    Now when you preview the result, the comet should fly on screen from the left and the effect should complete just a couple of frames before the end of the layer in the timeline.
    Please let me know if this works for you and if not then let me know how I can help you generate the effect by describing exactly how you would like it to look.
    I hope this helps,
    Peter.
  • Steve Pankow
    November 20, 2009 at 3:15 am
    Thanks. It works as you described. It’s just that having the completion value set to 50 seems counter-intuitive.
