Activity Forums Adobe After Effects Combustion to After Effects
  • Combustion to After Effects
    Posted by Juan Torres on March 24, 2009 at 7:16 pm
    Hi guys, I created a graphic in combustion and rendered it out as a tiff and a tga, however I can’t get the black background on the graphic to become transparent in after effects, I think it has to do with the alpha, not quite sure though.
    Keep It Real
    Juan Torres replied 17 years, 5 months ago 27,416 Members · 2 Replies
  • Juan Torres
    March 24, 2009 at 9:43 pm
    Dave I tried what you mentioned, it didn’t work for me, In combustion, when in the render settings, I use the targa sequence as the format, premultiply with color is checked, and color+alpha is highlighted. The depth is 8 bit. I dont know if you are familiar with Combustion or not. I also tried a tiff sequence and could not get it to work.
    Keep It Real
  • Juan Torres
    March 30, 2009 at 3:07 am
    Hey thanks for your help. I eventually figured out what i was doing wrong and it was with combustion. The way i was setting up my graphic was incorrect. The rendering was fine, but when setting up my graphich i would just open combustion, new-particle then choose and animate one, which is incorrect. Correct method is new/composite, then right click the composite layer and click new/solid, right click the solid and click new/particle. Then it renders in a useable manner. Thanks again!
    Keep It Real
