Activity › Forums › Maxon Cinema 4D › combining two pieces into 1
  • combining two pieces into 1
    Posted by Michael Goldberg on May 6, 2010 at 7:05 pm
    Hi all,
    I wouldn’t consider myself a great modeler, but I’m trying to get better. One of the things I’ve run into often is combining two elements into one when they have different point structures. I’m not sure how to approach this. For example, I built the bottom portion of a cartoon house, and wanted to attatch the roof to it. I wanted the whole structure to be 1 piece, so I could put it under a hypernurbs and get clean smoothing. Does anyone have any easy suggestions on combining two pieces into 1 when the point structure is not the same?
    Mike
    Fred Homan replied 16 years, 4 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    May 6, 2010 at 9:33 pm
    You need to have reasonably good topology for HN so I would generally model the object as one piece to begin with. If you haven’t done that it’s usually a question of using a lot of bridge tool, moving points around with the slide tool, and if necessary adding or deleting geometry. Hard to say much more without seeing a scene file or screen shots.
  • Fred Homan
    May 7, 2010 at 5:34 am
    hi
    how about create a null object and drag all elements into it?
