Activity › Forums › Adobe After Effects › Combining two handheld shots
  • Combining two handheld shots
    Posted by Eli Rezik on November 16, 2015 at 4:14 pm
    Hi there,
    like the title says, I’m trying to combine two handheld shots of the same location. The angles are slight different and maybe even the frame size is a bit different (I can’t seem to be able to make an exact match using difference)
    I’ve stabilized both shots and combined them then brought the camera movement back for the main shot. but I can’t seem to get perfect results.
    Is there a better way to do so? or is there a way to improve the technique i’m already using?
    Thank you
    Eli
    Student of “Cinema And Television” at Tel-Aviv university.
    Eli Rezik replied 10 years, 10 months ago 3 Members · 4 Replies
