Activity Forums Maxon Cinema 4D Combining two different meshes that use one joint rig
  • Combining two different meshes that use one joint rig
    Posted by Brian Murphy on September 24, 2015 at 5:56 pm
    Hey guys,
    I have a character model with a hand that was modeled into a fist – no fingers, no geometry for them, just a round lump at the end of his forearm with a fist texture on it.
    I need to cut off the hand of the character and use a hand model (with fingers) to attach to the character’s wrist.
    The character and hand models are rigged and weighted using the same joint rig, I spent a lot of time on weighting the character so I don’t want to have to re-do it. I can’t figure out how to combine these meshes together so I can start welding the points between the two models. If I try this, either the character won’t animate any more or things stretch way off into infinity.
    Any ideas?
    Brian
    Brian Murphy replied 10 years, 11 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 24, 2015 at 8:10 pm
    You could try making a copy of the model, attaching the hand, and then use the Character tools’ VAMP utility to transfer the weights from the original model to the new one.
  • Brian Murphy
    September 24, 2015 at 9:09 pm
    Fantastic, wow, that worked great!
    Adam, you’re always enlightening me to something in Cinema – never even used VAMP before.
    Thank you for the response!
    Brian
