Activity Forums Adobe Photoshop Combining texture parts to 1 image
  • Combining texture parts to 1 image
    Posted by Brecht Debackere on February 14, 2008 at 9:23 pm
    Hello!
    Is there a clever way to combine a series of pictures into 1 image without doing it manually? I have some sets of 512 pictures which are named tx_0_0…tx_0_15… up untill tx_31_15.
    The first nr. represents the collumn the second the row where the tile is supposed to go.
    Regards,
    Brecht
    Brecht Debackere replied 18 years, 7 months ago 2 Members · 3 Replies
  • Ekim Wahs
    February 15, 2008 at 12:05 am
    What happens if you use contact sheet with zero spacing between columns and rows and no label? File/Automate/ContactSheetII (in CS3)
  • Brecht Debackere
    February 15, 2008 at 10:36 am
    That works very well indeed!
    Thank you, I wasn’t aware of the contactsheet functionallity.
  • Brecht Debackere
    February 15, 2008 at 1:40 pm
    Is there a way to retain the alpha layer when using the contactsheet automation…?
    To answer my own question: yes.
    The files I have only have an alpha channel, the contactsheet automation flattened everything leaving me with just a white image.
    Now :
    I’ve created an action which copies the alpha channel to the rgb channels, after the batch is done, I run contactsheet. On the final big image, I copy the rgb channels, create a new alpha, and copy the rgb into it.
