Activity › Forums › Adobe After Effects Expressions › Combining setFont with variable sourceText
  • Combining setFont with variable sourceText
    Posted by Christopher Rutherford on September 22, 2021 at 11:44 pm
    I’ve got a dozens of text layers that pull text information from their comp names. I’m also trying to set it up such that half of the text is in one typeface and the other is in another typeface. Currently my expression is as follows
    thisComp.name.split(“-“)[1] + “$” + random (1, 10).toFixed(2)
    Is there a way to set it up such that the thisComp.name.split is in one font and the rest of it is in another? I’d assume I’d need a “var array=” thing in it, but I’m not quite sure how to marry the two expressions.
    Andrei Popa replied 4 years, 12 months ago 2 Members · 1 Reply
  • Andrei Popa
    September 23, 2021 at 5:55 am
    It is not possible to set different fonts in a single layer via expressions.
    If the only difference between the fonts is italic/bold/regular, you can try to mimic the look by using a text animator and setting different skew/stroke width for a part of the text.
