Activity Forums VEGAS Pro Combining projects help
  • Combining projects help
    Posted by Carson Young on January 4, 2007 at 5:53 pm
    Hi everyone, im currently working on a project that is saved as two different projects. I need to combine them, but am not sure the best way to do this. I’ve entertained the thought of copy and paste from one to the other, but i have way too many lines of info to select all of them at once using control shift that is. The other thought I had was to render the one part and then import it to the other as an mpeg. Any thoughts on the best way to handle this situation?
    Thanx,
    Carson Young
    Mike Kujbida replied 19 years, 8 months ago 3 Members · 2 Replies
  • Edward Troxel
    January 4, 2007 at 8:06 pm
    A couple of options:
    1) Nested VEG files – just drag the second VEG file to the end of the first project.
    2) Rendering – just render the pieces and make a “final” project from the renders.
    Edward Troxel
    JETDV Scripts
  • Mike Kujbida
    January 4, 2007 at 8:07 pm
    Are you using the full version (not Movie Studio) of (at least) Vegas 6.
    If so, nested vegs are what you want to do.
    Save #1 as project1.veg
    Save #2 as project2.veg
    Start a new project and import project1.veg and project2.veg just like you would with any media.
    Drop them on your timeline and save as project1-master.veg
    You should know that, if your original had multiple audio and/or video tracks, everything will be still there but it will now be one track each of audio and video.
    You can still edit it by right clicking the video portion and selecting “Edit Source Project”.
    This will start a new instance of Vegas with the original project. Make any necessary changes, re-save it and both project1.veg and project1-master.veg will be updated.
