Activity Forums Adobe Photoshop Combining Paths
  • Combining Paths
    Posted by Norman Walsh on May 20, 2005 at 12:36 pm
    I have just started learning how to use the Pen tool.
    So I have this image of a car which I want to copy into a different background, I adopted the following proceedure:
    Using the Pen tool I created 5 paths one for the outside of the car the other four for the windows.
    I had the Add to Path icon selected in the Options bar.
    The reason I drew paths for the windows was because I wanted the background to show through.
    Now my question is this: I can Control Click each path to turn it into a selection, so does that mean I have to drag the 5 selections seperately into the new background?
    Or is there a way of combining them before moving.
    Thanks a lot for any replies.
    Norm
    Norman Walsh replied 21 years, 4 months ago 2 Members · 2 Replies
  • Jeff Cochran
    May 22, 2005 at 4:18 pm
    You can do one of two things:
    1. Hold down the shift key when you control click and click all the paths – this will make one selection from all the paths.
    2. click on a path, copy, then click on another path and past – this will combine the paths
    For future reference, you can draw all the elements of the path as one path and save yourself a step. The only time you’ll run into problems is when two or more paths overlay each other. This will create a cut out in the selection.
    Good luck
    Jeff Cochran
    https://www.jeffcochrandigitalartist.com/
  • Norman Walsh
    May 23, 2005 at 6:56 am
    Thanks Jeff
    Norman Walsh
