Activity › Forums › Maxon Cinema 4D › combining multiple files for a render
  • combining multiple files for a render
    Posted by Alex Mcmurray on October 18, 2014 at 11:26 pm
    I have returned to C4d (v12) after a long absence, with a question on scene files.
    As an example, I have a main scene (.c4d) file, say a large room, I also have a number of other (.c4d) sub-files containing objects that would appear in the room, say, chairs, tables, cabinets, etc.
    Assume that the coordinates of the objects in the sub-files are correct relative to the position that they would be in the main room file.
    Is it possible to have the main scene file (the room), call the individual sub-files at the render stage, without the sub-file objects being “physically” in the main scene.
    My main drawback is I am not sure of the correct terminology to look for if this exists in C4d.
    Alex Mcmurray replied 11 years, 11 months ago 3 Members · 5 Replies
  • Adam Trachtenberg
    October 18, 2014 at 11:49 pm
    I don’t think it’s possible in R12. More recent versions contain Xrefs which allow this sort of arrangement.
  • Brian Jones
    October 19, 2014 at 4:46 am
    FWIW 12 does have xrefs – I didn’t remember for sure either but I have a copy still…
  • Alex Mcmurray
    October 19, 2014 at 6:49 am
    Thank you so very much Adam & Brian, this is what I was hoping for.
    While R12 does have Xref, my Googling indicates that it was included from R13 onwards, so hopefully, the 12 Xref works the same way.
    Now to search for turorials.
  • Brian Jones
    October 19, 2014 at 4:39 pm
    xrefs got more powerful over the versions so tutes might do things that are not possible in 12. I found if you have a lot (hundreds) of them in a scene loading times were pretty slow and opted for instances for a project I was working on (which was in 12 I think). I don’t know if that was my fault or just the nature of the beast at that point.
  • Alex Mcmurray
    October 19, 2014 at 7:43 pm
    The tests I have done so far have not reached that point, but one of my assets has 340 plastic chair in an array, with 1 “real” one and the rest instances.
    Previously, navagating the scene took forever, (Old quad core running XP), tested this with Xref, there was a noticable speed increase, plus, the ability to ensable visibility with one click was an added bonus.
    My imagination is reaching overload with ideas of Xref usage.
    Thanks for all your help.
