Activity › Forums › Maxon Cinema 4D › Combining Multiple Dynamics Objects
  • Combining Multiple Dynamics Objects
    Posted by Michael Goldberg on December 18, 2013 at 4:30 pm
    Hi All,
    I’ve been scratching my head over this issue for several days now…..
    I have a box, that is connected to a bar via a spring.
    The box falls down, and the bottom hinges open, and a piece of text falls out of the box. This text element is also held by a spring.
    I can’t seem to get everything to work without one part of the dynamics simulation interfering with the other. In my example, I had to disable a hinge connector for the bottom of the box, and keyframe that. I’d rather have everything work dynamically. Once I get the first drop to work (with keyframes for the bottom hinge), I can’t even get the text to drop without strange collision issues. I’m trying to a – get the second drop to work, then b – get the second spring connecting the text to the box to work, then c – somehow have the hinge on the bottom be dynamic as opposed to keyframed.
    I’m hoping someone can take a look at my sample scene, and see something that will put me on the right path.
    Mike
    Using C4D V15
    6923_springhingetest1.c4d.zip
    Spring Hinge Test 1
    Michael Goldberg replied 12 years, 9 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    December 18, 2013 at 5:57 pm
    Dynamics can be quite tricky. The main problem in your file is that you have the main box’s collision set to automatic, which in effect assigns a collision shape in the form of a solid cube. You need to set that “moving mesh”.
    I’ve played around with your file to get something close to what I think you’re looking for. It’s going to be tough because the spring connector’s themselves don’t recognize collisions. I made quite a few tweaks, including to the box and letter’s damping settings. I made the hinge work by keyframing its angle limit.
    File: 6925_springhingetest1amt.c4d.zip
  • Michael Goldberg
    December 19, 2013 at 6:30 pm
    Thanks Adam,
    I’ll play around with some of these settings.
    Mike
