Activity Forums Compression Techniques combining mpeg files
  • combining mpeg files
    Posted by Peter Robertson on June 6, 2012 at 4:56 pm
    I’m using this:
    ffmpeg cat test_0.mpeg test_12.mpeg > comp.mpeg
    to combine to files. The output file (comp.mpeg) is only the second file. Each of the input files is 10 seconds. Am I missing something here? Why is my first file not merged with the second??
    Thanks.
    Pedro
    Pedro
    Stephen Dixon replied 14 years, 2 months ago 3 Members · 3 Replies
  • Reuben Martin
    June 7, 2012 at 3:04 am
    cat test_0.mpeg test_12.mpeg | ffmpeg -i - -vcodec copy -acodec copy -f mpeg comp.mpeg
  • Peter Robertson
    June 8, 2012 at 4:54 pm
    That works! Thanks.
    Pedro
    Pedro
  • Stephen Dixon
    June 12, 2012 at 12:42 pm
    You don’t need to pipe it through ffmpeg. What you’re doing wrong is using > instead of >>
    The single angle brace overwrites whatever’s already in the file, the double brace appends it to the end. See section 3.6.3 here
