Activity Forums Apple Final Cut Pro Legacy Combining media for two projects
  • Combining media for two projects
    Posted by Antonio Scarpitta on May 17, 2010 at 5:24 pm
    Hello all,
    We are working on FCP6. I have a project that was not logged right, we have around 40 hours of interviews and b-roll but there are no comments, or any pertinent information for any of the clips. So I have an assistant working remotely watching the interviews and doing the logging while I work on some cuts. I am going through some of the same interviews myself, kind of fast so I can make some preliminary cuts.
    We both have the same media in our projects. She is now sending me interviews with all the markers and comments for each clip. They are the same clips I have in my project but now they all have the right markers and comments to them.
    I try just opening both projects into one and then move her clips to mine, I get a box telling me:
    “A master clip already exists for the clip you are adding, etc.”
    For the existing master clip in this project, use properties from:
    1. the clip you are adding
    2. The existing clip in this project
    or
    3. Create a new master clip and any necessary affiliates using properties from the clip you are adding
    Each one of this options does not replace the existing clip with the markers from the incoming clip, all they do is copy the new clip to my project, leaving the old one intact.
    My question is what is the best way to combine what she’s sending me with the project I am working on?
    Thanks in advance
    Jeremy Garchow replied 16 years, 4 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    May 17, 2010 at 6:39 pm
    Make a third, new project and combine your clips with her clips.
    Or
    Delete your old clips out your project before bringing in her new clips.
    Jeremy
