Activity Forums Adobe After Effects combining fields from seperate source video
  • combining fields from seperate source video
    Posted by Simon Mills on February 13, 2008 at 4:02 pm
    Hello,
    My Q on this forum is:
    Is it possible to combine fields from separate source videos i.e mix the lower field from one source and the upper from another and render this out interlaced ?
    Is there a plugin that might do the job?
    All the best,
    SM
    I wanted to register as ‘Natternoise’, using my Real Name’s not as fun
    Pierre Jasmin replied 18 years, 6 months ago 5 Members · 5 Replies
  • Kevin Camp
    February 13, 2008 at 4:38 pm
    this has actually been discussed before…. i can’t remember all the solutions, but one of the easier ways seemed to be the ‘3d glasses’ effect.
    it has the capability to let you select a source layer for the upper field and a source layer for the lower field. not exactly the purpose of the effect, but it think it should work for what you are asking.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Steve Roberts
    February 13, 2008 at 4:56 pm
    Brilliant, Kevin — that’s it. The effect (under “perspective”) settings would probably be:
    Left view: one footage layer
    Right view: the other footage layer
    Convergence offset: 0
    3D view: interlace Upper L Lower R
  • Simon Bonner
    February 13, 2008 at 5:01 pm
    Maltaannon’s slo mo tutorial at maltaannon.com gives a way doing this i think.
    Simon Bonner
    youtube.com/simonsaysFX
  • Simon Mills
    February 13, 2008 at 8:58 pm
    Thanks everyone for your input.
    Dave, I followed your instructions (a logical process when I think about it) and got the desired result.
    I had thought it may create an interesting ghosting effect to 2 separate moving elements filmed against the same static background. Just experimenting.
    Cheers,
    SM
  • Pierre Jasmin
    February 14, 2008 at 8:13 pm
    For your info
    The Reinterlacer in FieldsKit can do that
    Pierre
    http://www.revisionfx.com
