Activity Forums Adobe After Effects Expressions Combining Expressions
  • Combining Expressions
    Posted by Joao Monteiro on September 17, 2014 at 11:11 am
    I’ve 600layers from illustrator (like particles).
    Have keyframed them individually (argg). – position
    Have added an expression to smooth those keyframes with a little bounce.
    Have also added a keyframe offset of 10 frames.
    Now I want each particle to wiggle as well. How can I add a simple wiggle(2,5)??
    Thanks in advance
    Joao Monteiro
    // smooth position keyframes bounce //
    amp = .6;
    freq = 2.0;
    decay = 2.0;
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time){
    n--;
    if (n == 0){ t = 0;
    }else{
    t = time - key(n).time;
    if (n > 0 && t < 1){
    v = velocityAtTime(key(n).time - thisComp.frameDuration/10);
    value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
    }else{
    value
    // offset frames expression //
    maxOffset = 10; // frames
    seedRandom(index,true);
    offset = framesToTime(random(maxOffset));
    valueAtTime(time-offset);
    Jan Míka replied 11 years, 7 months ago 3 Members · 6 Replies
  • Joao Monteiro
    September 17, 2014 at 12:35 pm
    When I say Add I mean combine.
  • Dan Ebberts
    September 17, 2014 at 1:56 pm
    Towards the end of the first expression, try replacing each of the two occurrences of value with wiggle(2,5)
    Dan
  • Joao Monteiro
    September 18, 2014 at 2:46 pm
    Thanks Dan.
    It worked perfectly.
    Thank you.
    I was trying value+(wiggle(2,5))
    which wasn’t working.
    J
  • Jan Míka
    January 30, 2015 at 7:31 pm
    Hi Dan… I’ve got a similar problem, so that’s why I’m reading your posts actually…
    I want my Null_01 to be parented with a Null_02 in a different composition and to wiggle at the same time. I use variables for position (P) and for wiggle (W).
    All is applied in Ypos parameter:
    P = comp(“my other comp”).layer(“Null_02”).transform.yPosition;
    W = wiggle (10,10);
    How should the last line look like? I tried P+W; It works fine but the Null_01 moves to a crazy position… Any idea?
    Thank you very much!
  • Dan Ebberts
    January 30, 2015 at 9:24 pm
    Either of these should work:
    W = wiggle (10,10)-value;
    P + W
    P = comp(“my other comp”).layer(“Null_02”).transform.yPosition.wiggle(10,10);
    Dan
  • Jan Míka
    February 2, 2015 at 8:59 am
    Excellent! Thank you so much! Honza
